คงไม่นะคับโจ๊ก ยังยึดติด NA เหนียวแน่นไม่เปลี่ยนแปลง
ผมรักเดียว ใจเดียว ถึงจะรักเดี๋ยวเดียวก็เหอะ (ยังไงฟะ)
ส่วน New MX-5 Miata 2012 คงจะได้เกิดในปีนี้ หรือต้นปีหน้าอย่างช้า
ถ้าว่ากันตามข่าวฝั่งอเมริกา น่าจะออกมาอย่างที่ว่าข้างล่างนี้
The new MX5 Miata will come to the world in 2012 and will use MazdaUSAs outgoing Nagare design language, as autocar reports.
The Nagare design language is inspired by natures flowing elements and is used on the new 2012 Mazda MX5 in order to make the most out of it - and inspire the affordable sports cars nation - the only series vehicle to have received it is the newly designed 2012 Mazda Mazda5, a vehicle that showcases the design language but has a different buying segment to satisfy.
The Nagare design language is inspired by natures flowing elements will not be featured on any more of the new Mazda concepts. It will be replaced by a new design direction this fall to continue Mazda USA's direction to break new ground stay on the edge of excitement.
The technical side of Mazda USA has considered that the new Mazda MX5 model is starting to drift away from the original vehicles philosophy. The Japanese automotive maker has chosen to set a weight target of 1,000 kg (2,200 lbs) for the new MX5 Miata. This would allow the model to offer pure driving pleasure (Zoom-Zoom experience) and also keep the fuel economy high and the CO2 emissions low.
MazdaUSA's engineers are still weighing the best fit for this affordable sports cars power plant that will be found under the hood of the next generation of the roadster. The newest engine design from MazdaUSA is the leading guess which includes two Sky-G petrol units (the Sky-G engines are specifically built for increased efficiency). The main considerations are the 1.6 liter and the 1.8 liter engine. The engines will come with the 6 speed manual transmission standard for the new 2012 Mazda MX5 Miata
